tranny filter
take the pan off, remove the filter, install spacer gasket between the spacer and valve body , feed the screws up through the new filter / spacer/ gasket to valve body. tighten. then add the new pan and gasket. do not overtighten the pan bolts. you will need an extra quart of fluid
Make sure you put the extended pickup and filter back on exactly like they came off, I do beleve you can out them back on 180 out and then the hole won't line up for the pickup. just an fyi.
