tranny fluid pan
if you overtighten the bolts, it pinches the gasket and they seperate. these need to be tightened to their specific torque. i always make sure they are clean a dry and that the bolt holes arent sucked in . i always use a thin layer of permatex
904 is 4295875ac
get that gasket from the dealer...rubber with wire core....reuse able also
ok,,,keep using the fel pro and keep leaking fluid..
