R robs 67plymouth motown graffiti crusier Joined Feb 4, 2009 Messages 159 Reaction score 1 Location Manteca CA Mar 23, 2009 #1 when doing the 440 727 swap what tranny mount do i get. my original was 904 mount which one do i need? my crossmember has 1 bolt comin thru for mount
wjaholic My car stole my wallet! Joined Jul 10, 2006 Messages 231 Reaction score 0 Location 50 Miles from the middle Mar 23, 2009 #2 I cant speak for anything older than my '74 Duster but when I swapped in my 440/727 I used the original transmission crossmember (That I re-welded and re-enforced) with a poly transmission mount. No big modifications were needed.
J Jim Lusk Well-Known Member Joined Mar 8, 2006 Messages 6,248 Reaction score 3,200 Location Fresno, CA Mar 24, 2009 #3 Within given year ranges all a-bodies used the same trans mount, regardless of engine/trans combinations. So, put simply, use your original.
D dusterdon Well-Known Member Joined Feb 18, 2005 Messages 1,384 Reaction score 9 Location detroit area Mar 25, 2009 #4 The 73-up crossmember and mount is a better mount and will fit earlier cars. Its the one pictured in wjaholic's post.
J jamesdart Well-Known Member Joined May 6, 2007 Messages 1,522 Reaction score 63 Apr 3, 2009 #5 use your stocker just slot the hole t ofit. one of my cars i made my own spool mount with 2"x 1/4" flatbar.
