727 trans & 3000 hughes converter. Trans is for SB, and built by "Tom Chamberlin Custom Engines & Transmissions" of South Jersey. It was behind a 550 hp small block with 3000 mi. Full manual reverse pattern and will take 1000 hp. Double wrap band, 5 clutch Hemi front drum, 5.0 arm, 4 gear plannets etc. etc. Converter is a Hughes 3000 stall and goes right up to 3000 when flashed. Replaced trans with A500 over drive so that I was able to get on the freeway with 4.56 gears and not get the finger! $700 plus the ride, or pick-up from SW Florida. PM for pics. I can't upload from here for some reasone.
