trans cooler line fittings
Rapid Robert
Lincoln Nebraska
the female fitting that slides on the cooler line(s), are these available? someone posted a site with a zillion fittings that I saved, if available new what are they called so I can search the site? thank you for your time. RR
found it, it is a compression nut, thanks Mike! RR
This is a compression nut
Just go to the hardware store if you need compression fittings. Common.
