Trans cooler recommendations........
DGrace
Snow Hill, NC
Hello all. Looking to get a trans cooler & wanted to know what you guys are using. I've read that the plate style cools better and was considering the B&M Super Cooler. Going with the biggest I can afford - at least 11"x8". I also looked at a Summit Racing branded one and several eBay offerings that look very similar. It seems not much is made in the USA anymore and what is, I can't afford. Gotta save where I can but don't want to buy junk. Any experience would be appreciated. Also, I want to use AN fittings and braided line - what size (-6 or -8?) and do you guys run them through the radiator cooler or bypass it? Planning a 470 big block with a 727 w/ manual reverse vb. Thank you in advance for any help. <><
what i run: biggest plate style i can fit with built in -6 fittings. steel braided to the trans and not through the radiator. want to know if it works? run a temp gauge
Yes, the largest stacked plate cooler that will fit with the largest BTU rating. Brand is really of no consequence.
Thanks - that was my plan. I have the B&M aluminum deep pan that has the port for a temp sending unit. What brand cooler are you using?
Do you think it's worth a try to get an eBay cooler? $50 - $60 for a 25 - 30 row stacked plate one. The Summit Racing branded one looks "identical" and is about $110. I imagine they're "all" made overseas.....
I'd run the EBay one in a minute.
i agree, by biggest i was talking BTU'S. the last couple have been DERALE's but use what ever you like. i do make sure that they already have the proper fittings built in. just be careful how it's going to fit.
edit: some coolers also have a GVW rating. again bigger is better :)
one thing to think about, do you really want to use the cheesy ziptie through your nice radiator method, or plan on fabing some mounts to hold it properly
I
Thank you. I've read many of your posts/replies and that's just the "confirmation" I was looking for. Based on price (and my budget) the eBay one was looking pretty good - I guess I was just looking for input from people that tried them and had bad results. Thanks again. <><
Fabbing up a "cool" looking aluminum bracket. I have an aluminum radiator and fear vibration and ruptured tubes.....
I
Chances are, whoever makes those makes B&M, or Derele or all the rest.
describe your converter.
Don't have one.....yet. I may be doing it "backwards" but the engine & trans will be built last. While I'm saving for the $$ stuff, I do little (less expensive) projects to keep the fire burning. Recently completed my Moser fab 8.75 w/ Trutrac & 4.10 gears - ladder bars & coilovers. My Gerst tubular k frame came in 2 weeks ago and have to order the remaining parts in stages.... The target is a 10.90......
derale implies they make theirs here.
that one's a Hayden 689 i had on the shelf. probably built in the same factory
I think the B&M has 1/2" npt female threads. Have you been running it for a while with no issues?
that's the one on my valiant, 68' Valiant 4 door
haven't run it yet. soon as i get the wiring done and the interior back in, (next couple weeks i hope), i'll let you know
That one is around $70 and the same design/size as what I've been looking at so any feedback would be appreciated.......my build will take a little more than 2 more weeks......more like 2 more years. I was thinking/hoping that by 50 I could drive it.....that was 4 years ago.
ha, that's why i'm not letting myself get distracted by other things i probably should be doing
I plan on running this one from Derale....
i think that's the one in my dart. works very well
Another option that I have used with great success is a JY piece from a dakota/durango with tow package or a bit more compact one from the ford exploder/expedition. Get the ones with threaded fittings If you want to go AN-6 or some have barbed ends for hose.
A high quality converter like the dynamic 9 1/2 will have almost no slip
driving normally, but will flash to whatever specs it is built to.A converter
like this will make much less heat and you can neatly hide a little 5" x 11"
plate cooler most anywhere that will be more than adequate.
Discuss it with Dynamic or whoever builds your converter.
