Trans cooler recommendations........
OMG,
168 x 138 x 30 Inches, That thing is so massive i'm going to have to haul it on a trailer behind my car, probably cool the whole damn neighborhood.
Ha....Found other info that said its 11" x11" x 1 1/2"....Thanks a lot MoPowers exactly what I was looking for.
168x138 mm.
Dont want to create new thread...
I have 4 row Champion radiator with trans cooler MC375.
Trans has 3500 stall converter, no trans brake.
Will it make any sense to use radiator integrated cooler in this case?
Hello all. Looking to get a trans cooler & wanted to know what you guys are using. I've read that the plate style cools better and was considering the B&M Super Cooler. Going with the biggest I can afford - at least 11"x8". I also looked at a Summit Racing branded one and several eBay offerings that look very similar. It seems not much is made in the USA anymore and what is, I can't afford. Gotta save where I can but don't want to buy junk. Any experience would be appreciated. Also, I want to use AN fittings and braided line - what size (-6 or -8?) and do you guys run them through the radiator cooler or bypass it? Planning a 470 big block with a 727 w/ manual reverse vb. Thank you in advance for any help. <><
Here's what you want just like the b&m maybe 30% less. I got this on Amazon. I believe it was $80 shipped to my door. Half inch npt female fittings.
Yes sir made in Mexico just like the B&M
