Trans Line Bracket. How is it mounted?
Transmission and Drivetrain Tech
  1. Big_John
    Big_John In my defense, I was left unsupervised.
    375
    392
    Nov 16, 2014
    Syracuse, NY
    Local Time:
    4:17 AM
    I noticed that the trans line bracket at the bellhousing was missing from my '65 Formula S Barracuda. 273 with a 904 trans.
    After checking part numbers etc. I came up with this as a replacement. I think it's the right piece... or close enough anyway.
    I can't figure out what the orientation of the bracket is. If I put it so the lines fit, the bracket doesn't bolt to the bellhousing right. If I put it where I think it goes on the bellhousing, it doesn't clip to the lines.
    I'm not afraid to bend the lines to the right place, but I'd like to know what's right.
    Anyone have a good picture?
  2. lilfontleroy
    lilfontleroy annoyinglilLeroy FABO Gold Member
    2,797
    2516
    Nov 20, 2017
    Intercourse
    Local Time:
    3:17 AM
    just thinking out loud here ~ is that the one that goes up between the engine and oil pan?
  3. Big_John
    375
    392
    Nov 16, 2014
    Syracuse, NY
    Local Time:
    4:17 AM
    Yea, kinda. It's between the engine and the bellhousing, under the starter. The lower bolt that the engine to trans brace fastens to.
    This is the way I think it goes, clip facing towards the top and between the brace and the bellhousing. But it just doesn't look like what I've seen and remember.
  4. abdywgn
    abdywgn dismantler
    1,498
    748
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    3:17 AM
    bolt hole up under lower starter nut and tubes are underneath starter/bellhousing/bracket. Guessing...
  5. lilfontleroy
    2,797
    2516
    Nov 20, 2017
    Intercourse
    Local Time:
    3:17 AM
    you're in the right area, it's just a matter of orientation.. IIRC it doesn't point up as you have it, in fact I think it points down. Try seeing if there is a "sweet spot" where it feels like it's not forcing the lines together. It does attach to the bell housing ~ but you knew that.
    Someone will chime in here eventually with a definitive answer.
    • Thanks! Thanks! x 1
    • Hyper_pak
      Hyper_pak Old School Chrysler Fan
      2,965
      2081
      Feb 14, 2010
      Desoto Texas
      Local Time:
      3:17 AM
      With old or new lines, you most of the time end up re-forming at some point. When I did my slant I placed the bracket and then fit the lines so it would line up. It still was a PITA.
      • lilfontleroy
        2,797
        2516
        Nov 20, 2017
        Intercourse
        Local Time:
        3:17 AM
        found this, not a great image but I thought it might help
        • lilfontleroy
          2,797
          2516
          Nov 20, 2017
          Intercourse
          Local Time:
          3:17 AM
          does it go on the bolt that comes from the engine side? near the alignment pin
        • Big_John
          375
          392
          Nov 16, 2014
          Syracuse, NY
          Local Time:
          4:17 AM
          This hole, marked in red.
        • oldkimmer
          oldkimmer FABO Gold Member FABO Gold Member
          16,569
          4905
          Nov 11, 2006
          Kindersley, Saskatchewan,
          Local Time:
          3:17 AM
          So these older ones bolt to th bell unlike the newer ones that bolt to the lower starter stud? Thanks. Kim
        • Big_John
          375
          392
          Nov 16, 2014
          Syracuse, NY
          Local Time:
          4:17 AM
          I don't think it can mount anywhere except the lower bolt on the bellhousing. At least where the lines are passing along the side of trans on my car anyway.
          This is the parts manual.
          I needed to just get this done and ended up mounting it like this. I'd still like to know what the right way is, but at least it works in this position.
          • Like Like x 1
          • oldkimmer
            16,569
            4905
            Nov 11, 2006
            Local Time:
            3:17 AM
            Seems to fit there nicely. Kim
            • Agree Agree x 1
