Trans mount bolts
5/16" bolt 7/16" long - 24 threads per inch Grade 8. Mr Gasket has them at Oriely's or Autozone. Summit and Jeg's also have them, but you will pay shipping unless you order enough stuff. I picked some up yesterday. It took one day for O'Riely's to get them.
5/16 sounds small. I thought my Challenger used larger bolts to attach the trans mount. For some reason, I remember them taking a 5/8" socket.
Not positive about the length, but the mount is 3/16" thick and the washer would be 1/8" and you would want 3/4" in the hole, that would be 1 1/16" long minimum but I don't know the maximum.
The head size is 11/16, which would make the shaft size 7/16", and fine thread as stated above! The length I will check when I get home, I may have a couple for you! Geof
If you are talking about the bolts than thread into the transmission, they are a 5/8 inch head an a little over and inch long. I have some also.
I'm sorry, I was thinking torque converter to flex plate bolts. Disregard the above for your question.
