moparman72
Have noise in 833 4sp trans over 30 mph.Below that speed no noise.Trans was completely rebuilt by professional shop.What the heck!!!????
Is that "all those rollers " that you need a dummy shaft for? I wonder if a few or one is missing...it would be easy for a builder to do, lose/forget one upon assembly... but it would be found on the bench or floor at some point...I had bad cluster shaft bearings and it made noise in every gear and in neutral with the clutch out because the cluster is connected to the input shaft. In neutral w/ the clutch released raise the rpm and see if it makes any noise.
also they could be just shot pitted flats on them. I would think a good kit from brewers would have new rollers... but you are correct that shaft turns the whole time even in neutral I think...Yes that is it, mine was so bad it wiped out the shaft and the gear.
It makes the noise 30mph and above it stops as I slow down.How bout "does it make the noise rolling or sitting still or both?"
