trans question
For a magnum swap or hemi?
Seems like a lot of $$$ for a magnum swap and a hemi swap will cover both the wiring and controller duties with the factory pcm.
What are you trying to build?
I'm not sure what's really made and available for that setup. The megashift seems like it may be a cheaper option- but still over $250. While the idea of a 6spd auto behind a Magnum is nice- it may well be prohibitive to set up a controller for.
