H
I have moved it in both directions and still not right. Very frustrating.
won't that do away with Kickdown?
was wondering if I just could put a spring on it under the car and try without unhooking.
Is there room on the kickdown bracket at the tranny to drill another hole forward of the existing one ?? You may be able to allow yourself a little more wiggle room at the Top adjuster !! Just a thought !! I've had to do something similar with a console shifter in my last Dart !! If nothing else,just put a manual shift valve body in and enjoy playing !!
Looks like it's a modified setup to start with so it probably needs to be re-engineered a bit to get it working properly. To get it to shift later, you need a longer rod, more movement of the rod, or a shorter pivot point on the bottom lever. Your upper bell crank angle doesn't look quite right to me. Open your throttle all the way and see if the rod pushes the bottom lever on the trans all the way back. If not, you'll have to modify the linkage setup until it does. If the lever does go all the way back, you have an internal valve body problem. The throttle pressure linkage effects upshifts as well as downshifts.The 904 in my car shifts way too soon for me. Is this the only adjustment point to cure this?
I just ordered a Lokar Kickdown. I have fought this all day .
