The year of kit is unknown. It is from a friends car that had trans problems and all he knows it is a tf-3 kit in valvebody. So i am looking for some instructions so i can go through valvebody for him.
Here are some pics of the valve body. The only things I can see different so far without taking apart is the pressure regulator spring is blue and there is what looks to be a stiffner plate added to the rear.
.............If there is no other plate bolted to the bottom u have 1 of the 1st kits from the late 70s early 80s............the triangular plate is for the manual shift, it is foreward pattern...........the pr spring is only supposed to be at 6 turns maximum, looks to be 10 or more..........what kinds of issues was it having..........kim..........
It had converter failure that caused debris through trans. Valve body needs to come apart to be cleaned and inspected. I would like the instructions to know it is properly set-up when putting back together. Thanks
..............Good luck, hope it works out 4 ya......when u get into it, lmk as there is some things that i've learned along the way.......kim.............
