transmission/convertor b/b
ramhead
slinger wi
for sale crt 727 pro racetorqeflight billet steel front drum has reverse man valve body bolt in sprag alto red eagle clutches kolene steels redline bands teflon rings front/rear billet servos 4.2billet 2nd gear lever b&m deep panmodified pump support.Less than 10 passes also turbo action 069j convertor also less than 10 passes trans new was $1900.00 comes also with tci flex plate turbo action shifter and a lofgren trans blanket paper work on trans and convertor asking $2500.00
