GotDart
My Dart has always had a bad trans fluid leak. It leaves a large puddle, 1 or 2 quarts worth, whenever it's parked for a few days. I suppose it leaks down to a certain level, and then stops. I originally thought it was leaking at the pan, so I did a fluid/filter change. That didn't help. What are other common leak points I should check?
