I am doing a transmission swap on my original 1966 Dart from a column shifted manual 3-speed to A-904. I have got the correct transmission and steering column, now I am missing only the gear shift linkage and kick down linkage.
Getting original parts from a donor car is not easy here in Finland as most cars came with same manual 3-speed.
Would a "SC 1095 Steering Column Shift Cable Control Set" from Classic Industries work instead of the linkage set?
Any ideas or suggestions would be very much appreciated!
