Trick Flow Heads on Engine Power.
superchargeddrt
Pittsburgh, Pa.
Hey Guys,
Check out the power numbers on a 360. This was at 6200 RPM
Does TF list the short block specs anywhere?
Indeed. Actual displacement, compression ratio (a slug part number/description would be good.) & the cam spec & type.
that is a great show, I did not know about the trick flow intake. Super cool
There is a thread here on it. IIRC, it is probably a good year old or not more. TF had one at (IIRC) SEMA but stopped the release. For what ever reason.
sponsored by trick flow? I hate to be cynical, but to quote the Eagles marketing It's All That Heaven is. There is no way that I believe those numbers aren't possible in a 360 cubic inch with the right parts, I've just seen a lot of Parts elevating.
Are the trick flows SBM heads even selling...they have been around for at least a year and l don’t see a lot of builds with them so far
A guy in my group is building a 360 with them, awesome looking heads! He had them inspected and didn't find anything wrong a true bolt on head.
I believe they're probably a great head one of the best standard push rod location heads available for an LA but it's still the sum of the parts one member mounted them to his 340 and only gained around 10 horsepower over his old Brock's
I just figured that the way the locals were chomping at the bit for these heads that we would have had at least a half dozen builds going on here... but so far not much
There's 3 or 4 here I think. AARcuda is building one. I have a set and most everything I need. Just saving my nickels for the rest. Hoping to have it going by summer.
i think people were expecting or led to believe they were going to get a bolt on 600 hp head or a head that would blow the edelbrocks away but that didn't happen .
I agree.... I looked at buying them a few weeks back for a build and went W9’s instead
Someone, I think it was @pittsburghracer , mentioned talking to the TF guys last fall and they said it was one of their top three selling heads. It was one post in amongst the rest, so I don't have a link.
That's quite a leap....Were you under the impression that the TF would yield similar performance as a W9? Or just decide to go big or go home?
