805moparkid
Slant and AFX Guy
i bought a universal spark plug wires kit thru MSD and have the ends i need but everything is such a tight fit none of the ends will go on! any tricks to doing this?
use more stuff, inside the boot and outside of the wire.
messy is putting it mildly for sure. try cutting a taper in the insulation.
Like an old timer told me years ago"USE A LITTLE BRAKE FLUID, YOU CAN STRETCH A KNATS *** OVER A TELEPHONE POLE WITH A LITTLE BRAKE FLUID"
Ok I don't advise the brake fluid bit, but that old saying was the first thing that came to mind when I read your post. I've used WD-40 and the needle nose trick in the past.
If you got it 3 inches, why do you need more?
grr i felt like an elephant ****** all over my new wires!!! and my hands
I'm reminded of Clifford Franklin on The Replacements with the stickum comment ... "Now Coach you KNOW this don't look natural! I look like I just ja**ed off an elephant!"
And LMAO @ Terry too.
I love hangin out with the boys. :love7: Somehow, I just can't see working that in tactfully amongst lunch with the girls over a latte.
now for the truly sick since we are started down that path,ive actually used a little ky,or whatever personal naughty lube the wife and i have at the time
