Trick Shift and a 904?
4mulaSvaliant
Virginia Beach Va.
Hey all, anyone have an educated opinion on running trick shift only in my 904?
The only things I plan on doing to the trans is the typical adjustments to the bands and then put a transgo TF2 shift kit in it. I plan to run a standard rpm torque converter as well.
:scratch:
Use Type F trans fluid. I know its for Fords, but Trick Shift is type F fluid. Chrysler has been recommending Type F for high performance transmissions since forever. A lot cheaper, too.
don
