Trim clips
jhdeval
Carrollton, GA
I was removing the stainless trim from the upper rear quarters on my 65 Barracuda and one of my clips broke. Can I use the same clips used for the door panels or is there a different clip?
The door panel clips are different and probably won't work. I can send you a couple extra clips that are correct for the upper stainless. PM me with your address and I'll send a couple out!! Geof
