trim question on 69 Dart
A
Admin1
Guest
The kick panel at the bottom of the A post (this is on a 2 door hardtop) is in place. The sill plate is in place. What's NOT in place (cause I ain't got some) is the counterpart to the kick panel that covers the door mating edge on the B post. It runs from the sill plate up to the rear side window slot.
What is it? Rubber or plastic? :shock:
As always, thanks in advance,
Jim
Is it the piece that covers the pinch weld from the sill plate up to the window. If that's what you are talkin about then it is a colored vinyl piece that just slips over the pinch weld. Someone may have a picture. These were used on lots of different applications. so you may be able to find some in the boneyard. just cut to length. I think even brand X cars may have some.
