Truck engine mount ID help
bb66cuda
San Jose, CA
I’m trying to ID these 3 sets of engine mounts. I think they are all truck mounts but unsure what year and engines they came off of. I’m looking for the correct mounts to put a 318 in a 1972 D100.
More pictures of the mounts you have in the first picture could help. Second pic, Not for a 72 truck with a 318. Bolt spacing for engine block attachment is 2 inches, if there more, then they're big block. Passenger side, width is 3 1/8 inch and a somewhat centered mount hole. Driver side is 2 7/8 long and the mount hole favors the front of the mount, for a 318. Driver side attaches to the block behind the lugs, passenger side attaches to the block in front of the mount hole lugs.
Here are a few more pics. None match exactly to those numbers but spacing is 2”.
Pic 4 the mount is bloated, measure the spacing further down. The 2 cleaner ones , so far, look close to being right.
