trunk trouble
gsone1
Member
Can someone help with getting the decklid on my 1971 demon adjusted right,when the trunk is closed you can stick your finger between the rear valance panel and the trunk and you can see the trunk seal with the trunk closed, also need help getting the gaps on the sides of the trunk the same, hope someone can help as i'm not a body man lol..thanks in advance for your help....gsone
a pic would really help , but you can loosen the trunk latch and lower it so the lid will latch tighter
