Trust issues
General Discussion
  1. dartfreak75
    dartfreak75 Restore it, Dont part it! FABO Gold Member
    8,402
    5908
    Aug 10, 2011
    Virginia
    Local Time:
    12:28 PM
    This is exactly why I have a hard time believing anything I read or see. And this is why i ask alot of questions to the ones who have done these things and not just read about them. I know for a fact that the thrust plate has the slot facing inward when I took it apart. I have three books I reference one says to face the plate the correct way the other book clearly had it in backwards. Had I not already known or didnt own the other book I probably would have put on backwards. I wonder how many people have incorrectly assembled this part based on this particular book?
  2. 318willrun
    318willrun Utube channel 318willrun
    15,501
    16628
    Sep 13, 2013
    I'm here
    Local Time:
    11:28 AM
    What books??? I use Factory Shop Manuals, never really had that issue. I really don't bother with Haynes, etc.
    *P.S. - it IS under the performance tip.... LOL.. ya never know :D
    • Agree Agree x 1
    • dartfreak75
      8,402
      5908
      Aug 10, 2011
      Virginia
      Local Time:
      12:28 PM
      The one on the top is (correct) is how to hotrod a small block mopar by Larry Shepherd the middle (incorrect) is how to rebuild the small block mopar by William Burt the bottom photo is mine
      • Like Like x 1
      • Agree Agree x 1
      • '63GT
        '63GT Well-Known Member
        1,478
        1521
        Jun 9, 2018
        Turlock, CA.
        Local Time:
        9:28 AM
        Well, I can say I totally disagree with sending more oil to the chain..(drilled soft-plug)
        The main bearing does a pretty good job on it's own, that's why the deflector is used behind the sprocket..
        • Agree Agree x 2
        • Like Like x 1
        • dartfreak75
          8,402
          5908
          Aug 10, 2011
          Virginia
          Local Time:
          12:28 PM
          I have read and heard a lot of guys on here say to do it and it seems to make more sence to use the plug that the bolt to me.
        • '63GT
          1,478
          1521
          Jun 9, 2018
          Turlock, CA.
          Local Time:
          9:28 AM
          Yup. It's ok to have a healthy skepticism of some of the stuff the factory did... especially with the environment we put them in.
          We don't use nylon cam gears, 2 Bbls, or lazy cam profiles. that oil hole might be ok for a cab, but...
        • MOPAROFFICIAL
          MOPAROFFICIAL FABO Gold Member FABO Gold Member
          6,477
          5433
          Jun 1, 2016
          Beach
          Local Time:
          9:28 AM
          Thank you for speaking truth.
          I've never understood why people want more leaks in their 'as they themselves say' "already inadequate oiling system"..
          Oil just showers out of the bearings everywhere. 'Oil control' is what they should focus on.lol
          • Thanks! Thanks! x 1
          • Agree Agree x 1
          • Disagree Disagree x 1
          • toolmanmike
            toolmanmike FABO MODERATOR Staff Member FABO Gold Member
            52,967
            38457
            Jan 18, 2006
            Iowa
            Local Time:
            11:28 AM
            The slot should be inside to help lubricate the front cam journal that rubs on it. It's a oiling slot. The cam gear usually has it's own slots to oil the outside.
            • Agree Agree x 3
            • Like Like x 1
            • dartfreak75
              8,402
              5908
              Aug 10, 2011
              Virginia
              Local Time:
              12:28 PM
              I wish you guys would have voiced your opinion before i went and already drilled it! Haha i was a bit skeptical about doing it but literally everyone on here told me too and it was in the book so i did it. I dont think it will hurt nothing.
            • dartfreak75
              8,402
              5908
              Aug 10, 2011
              Virginia
              Local Time:
              12:28 PM
              Yea i knew luckily i just cant believe it printed in the book backwards
            • toolmanmike
              52,967
              38457
              Jan 18, 2006
              Iowa
              Local Time:
              11:28 AM
              Like "How to overhaul your engine in Facebook" LMAO
              • Agree Agree x 1
              • '63GT
                1,478
                1521
                Jun 9, 2018
                Turlock, CA.
                Local Time:
                9:28 AM
                Soft plugs are cheap.. maybe use a early model thrust plate too. (no holes over plugs)
                run a sheet metal screw into the hole and use 2 heal bars to get that one out.
              • yellow rose
                yellow rose Overnight Sensation
                24,548
                20544
                Jun 19, 2015
                Under The Gun
                Local Time:
                9:28 AM
                No, you did it correctly. The factory system is designed to get by warranty, and be the most basic, simple and cheap way to do it.
                That crap about enough oil in the timing cover, the stupid bolt with the hole in it, even the drip tab are all pretty much useless.
                • RustyRatRod
                  RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                  64,609
                  37574
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  12:28 PM
                  I never have liked drilling the oil galley plugs. AT ALL. I do however endorse drilling a hole in the center of that bottom bolt on the passenger's side of the thrust plate, though. That's kinda "free" oil because it just drips out of the intake valley under no pressure.
                  • Like Like x 1
                  • RustyRatRod
                    64,609
                    37574
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    12:28 PM
                    Well think of this......how many small blocks have you ever seen with burnt up timing chains from lack of oil? I've not seen any. I will say I have seen quite a few I KNOW were virgin tear downs that did have that little bolt with the hole drilled through it, so evidently Chrysler did think that was a good idea. It's cheap and it doesn't cause a pressure loss since it just drips out of the intake valley. Nothing wrong with doing that.
                    • dartfreak75
                      8,402
                      5908
                      Aug 10, 2011
                      Virginia
                      Local Time:
                      12:28 PM
                      That thrust plate didn't have the holes i put them there for the oil to the timing chain "mod" i was gonna do a hole in each plug like the book says but decided to just do one. Thats why there is a hole in both sides. Im gonna leave it there i dont think it will hurt to have extra oil there are alot of ppl doing it.
                    • RustyRatRod
                      64,609
                      37574
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      12:28 PM
                      It's a small hole. It won't hurt a thing.
                      • toolmanmike
                        52,967
                        38457
                        Jan 18, 2006
                        Iowa
                        Local Time:
                        11:28 AM
                        I drilled mine as well but only on one side. No issues and I am sure plenty of oil on the chain.
                        • Agree Agree x 1
                        • dartfreak75
                          8,402
                          5908
                          Aug 10, 2011
                          Virginia
                          Local Time:
                          12:28 PM
                          I was thinking the opposite way. I didnt like the idea of leaving the bolt out. And i didnt think that drilling the hole would provide enough oil to make a difference, but the pressurized galley would skirt a far amount of oil on the chain and it falls right back into the pan so im not "losing" any oil. But that was just my thinking. Im sure there has been thousands of engines ran all three ways without any issues
                        • dartfreak75
                          8,402
                          5908
                          Aug 10, 2011
                          Virginia
                          Local Time:
                          12:28 PM
                          I only did one side also. The thrust plate has one on both sides but only one plug.
                        • RustyRatRod
                          64,609
                          37574
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          12:28 PM
                          What I meant by losing oil was losing pressure. The drips from the hole in the bolt would be plenty. But as mentioned, even without the hole through the bolt or the hole in the galley plug, the chain gets adequate oiling.
                          • kursplat
                            kursplat FABO Gold Member FABO Gold Member
                            3,466
                            2319
                            Aug 24, 2010
                            so cal
                            Local Time:
                            9:28 AM
                            ...:rolleyes:
                            instructions at bottom
                          • dartfreak75
                            8,402
                            5908
                            Aug 10, 2011
                            Virginia
                            Local Time:
                            12:28 PM
                          • dartfreak75
                            8,402
                            5908
                            Aug 10, 2011
                            Virginia
                            Local Time:
                            12:28 PM
                          • kursplat
                            3,466
                            2319
                            Aug 24, 2010
                            so cal
                            Local Time:
                            9:28 AM
                            :lol:
