dartfreak75
Restore it, Dont part it!
Two different books the first one is correct the other is not. Lol
Hopefully it won't loose that much pressure that is the galley that feeds the liftersWhat I meant by losing oil was losing pressure. The drips from the hole in the bolt would be plenty. But as mentioned, even without the hole through the bolt or the hole in the galley plug, the chain gets adequate oiling.
Lol thanks.It'll be fine. Like it has EDM lifters. But it doesn't. lol
Truth is you can flip it, file a notch and you're good. So it being backwards in the book pic is no real to do. Besides the one in the pic has a groove that would bleed off that mod before the hole.Yea i knew luckily i just cant believe it printed in the book backwards
