TTI 1 7/8 Headers hitting oil pan
Mopar Exhaust Systems
  1. Walker434
    Walker434 Well-Known Member
    938
    609
    Aug 29, 2012
    Nashville, TN
    Local Time:
    2:51 AM
    I have TTI 1 7/8 race headers and just installed new engine in my 71 Dart. It has a milidon road race oil pan and one header tube is resting on the top of the kick out.
    Any tips on getting clearance without removing engine or headers? This is on the drivers side and this header was a nightmare to install. It's only touching on one small portion. Thought about a flat blade screwdriver and hammer but I'm afraid of damaging the oil pan. Thanks in advance for any helpful tips or tricks.
  2. jrcr_15
    jrcr_15 Well-Known Member
    108
    31
    Jan 3, 2006
    Local Time:
    2:51 AM
    You might have some luck with a C-clamp..? But taking them off might be the best option. I have tti's on my Duster and they were brutal to fit correctly
  3. yellow rose
    yellow rose Master Of Insanity
    23,908
    19917
    Jun 19, 2015
    Walking a crooked mile
    Local Time:
    12:51 AM
    Any time the tubes get that big it's hard to make them fit. Double check engine placement. If you can move the engine a bit in the K frame you may find some room.
    Good, HP making headers are always a PITA. Cheap headers that fit nice usually lose power.
    • Disagree Disagree x 2
    • Like Like x 1
    • diymirage
      diymirage HP@idle > hondaHP@redline
      19,932
      14162
      Oct 12, 2012
      michigan
      Local Time:
      3:51 AM
      if it were me, i would pull the pan, cut out the kickout and reweld it some
      almost seems like the only way to deal with it...unless you want to try to reshape the headers
      thats the problem with aftermarket parts, they might fit perfectly on their own, but when you put them together they dont always play nice
      • Agree Agree x 5
      • Like Like x 1
      • 72bluNblu
        72bluNblu FABO Gold Member FABO Gold Member
        11,001
        5444
        Nov 28, 2008
        NorCal
        Local Time:
        12:51 AM
        You’re going to have to drop the pan or the header to fix that. I don’t think you’ll have any luck at all solving that without removing one or the other. You may try loosening the header up and seeing if you can move it a little on the studs, but that looks tight and you may not buy enough clearance that way. Shifting the engine in the mounts won’t help at all, both the pan and the header are bolted to the engine.
        I’d dimple the header before I messed with the oil pan too. There are dyno tests out there showing that dimpling the headers has pretty much no effect on horsepower output. If you section the pan you’ll have to make sure it doesn’t mess with any of the baffles or trap doors that pan has. Not to mention if there’s oil in it now you’ll have to do a lot of cleaning to pull off the weld you’ll need.
        I have a set of Doug’s headers on my 340 with a Milodon road race pan. The fit is definitely tight, but they cleared the pan ok. They’re 1 5/8” though.
      • 72Dart6pack
        72Dart6pack Harder Better Faster Stronger.
        3,695
        3467
        Feb 1, 2016
        Roseville Michigan
        Local Time:
        3:51 AM
        Note to self: You're outta luck. Something is coming off to fix it.
        • Agree Agree x 1
        • famous bob
          famous bob mopar misfit
          17,269
          6800
          Aug 14, 2011
          okla
          Local Time:
          2:51 AM
          My sentiments exactly^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
          I bought an old funny alum. funny car , 7 qt pan, and had to do the same thing , only to the front /to clear my aftermarket front end. Still a bitch to get off , but do able.
        • moparspares
          moparspares Well-Known Member
          580
          50
          Aug 10, 2010
          Scarborough, Qld
          Local Time:
          2:51 AM
          I feel your Pain. 1 7/8 headers in an A body biggest mistake of my life. Never Ever Ever will I do that again. Had mine out a couple of times and they have flat spots all over them to make them fit. For TTI to say they fit out of the box is absoloute crap and I installed mine as per the letter of TTI instructions using all there suggested parts.
        • canyncarvr
          canyncarvr Well-Known Member
          129
          23
          Dec 31, 2011
          State of Jefferson
          Local Time:
          12:51 AM
          Not applicable to your situation, BUT: My one-each Hedman header of the nominal size (1-5/8") didn't fit with my Milodon pan without some 'persuasion' to the header with a hammer.
          It is also true that my Milodon pan is not shaped like yours.
          It's maybe not JUST the 1-7/8" part of the equation that's a problem.
        • Walker434
          938
          609
          Aug 29, 2012
          Nashville, TN
          Local Time:
          2:51 AM
          I've made a decision. I'm going to try to C clamp the header tube as close to the oil pan as possible. Hopefully this will give a little clearance so I can get a tire spoon (like the one shown) in there and beet the shit out of it with a hammer. If I damage the oil pan oh well, it was going to have to be modified anyway. If not, it might work and I win!
          Am I crazy or not?
        • yellow rose
          23,908
          19917
          Jun 19, 2015
          Local Time:
          12:51 AM
          I've used multiple sets of Hooker 5303 headers (can't even buy them any more) and they all fit well. You can't have power steering. They are a PITA to install but they fit well, you can get to all the spark plugs and they make power.
        • diymirage
          19,932
          14162
          Oct 12, 2012
          michigan
          Local Time:
          3:51 AM
          if you gonna bash on it, warm it up as much as you can to make the metal a bit more pliable
          • Agree Agree x 1
          • Walker434
            938
            609
            Aug 29, 2012
            Nashville, TN
            Local Time:
            2:51 AM
            Yeah that's the plan. Heat it up with the torch first. Currently no oil in the pan so don't have to worry about that.
          • Divenut
            Divenut Well-Known Member
            3,131
            1449
            Sep 22, 2011
            Naperville Illinois
            Local Time:
            2:51 AM
            It's amazing what one can fix, and/or make fit, with a bit of persuasion from a BFH.
          • 69FBCuda
            69FBCuda Life in the Fast Lane FABO Gold Member
            2,724
            1425
            Aug 28, 2014
            Florida
            Local Time:
            3:51 AM
            Drop the pan and ball peen the header and pan
          • canyncarvr
            129
            23
            Dec 31, 2011
            State of Jefferson
            Local Time:
            12:51 AM
            But....there WAS oil in the pan? I would be less concerned with heating a pan full of oil than one empty and full of fumes. Liquid gasoline will quench a match.
            Have some extinguishers on hand! Stick a shop vac on a valve cover hole prior to lighting it up with a torch. Maybe just use a heat gun?
            If you get a bit of space between the two, how about gluing a piece of gasket material (something relatively hard and thick) to the pan at that point; kind of a heat shield.
            I did that. The 'effectiveness' may have only been in my head...but I did feel better about it.
            It's all about 'feelings', right?
          • diymirage
            19,932
            14162
            Oct 12, 2012
            michigan
            Local Time:
            3:51 AM
            • Like Like x 1
            • mbaird
              mbaird mbaird
              6,129
              3002
              Dec 10, 2005
              boise, Id
              Local Time:
              1:51 AM
              I have 1 7/8 race W2s and the Kevco 6qt pan... fits great.
              I would hammer a wedge in between the pan and pipe ... slow taper wedge.. Then heat up the pipe and use a heavy rubber mallet to whack the pipe against the wedge. Might work without anialating the pipe
            • mbaird
              mbaird mbaird
              6,129
              3002
              Dec 10, 2005
              boise, Id
              Local Time:
              1:51 AM
              This is why I drop my car on the Motor/trany/ Kmember assembly. You can mock everything up out of the car and it takes about 15-20 minutes to get it bolted in.
            • jimjimjimmy
              jimjimjimmy lobsterman FABO Gold Member
              4,440
              1240
              Nov 2, 2010
              p. e. i.
              Local Time:
              4:51 AM
              I would fix it right and not beat on anything but that's just me .
              • Agree Agree x 2
              • moparspares
                580
                50
                Aug 10, 2010
                Scarborough, Qld
                Local Time:
                2:51 AM
                Sometimes you just gotta beat on them. If you are using all the correct parts around them and they are still touching you have no other choice.
                • Agree Agree x 1
                • jimjimjimmy
                  4,440
                  1240
                  Nov 2, 2010
                  p. e. i.
                  Local Time:
                  4:51 AM
                  take the pan off, cut out the interference, fit a new piece of metal, tig weld it . that's hot rodding .
                  • Agree Agree x 2
                  • canyncarvr
                    129
                    23
                    Dec 31, 2011
                    State of Jefferson
                    Local Time:
                    12:51 AM
                    My Weller doesn't go up to 'tig'.
                  • 72bluNblu
                    11,001
                    5444
                    Nov 28, 2008
                    NorCal
                    Local Time:
                    12:51 AM
                    You’re crazy.
                    Drop the pan and dimple the headers. Doing what you describe is gonna damage everything.
                    Chasing oil leaks from the pan damage is going to be an even bigger pain than the interference you have now.
                    • Agree Agree x 1
                    • mbaird
                      mbaird mbaird
                      6,129
                      3002
                      Dec 10, 2005
                      boise, Id
                      Local Time:
                      1:51 AM
                      He will have to pull headers to get the pan off. And pull the engine to get the headers off.
                      For those that have never installed an engine assembly from below it really is the easiest way once you figure it out.
                      • Disagree Disagree x 1
