TTI A body tail pipes
AdamR
Big Member
Bethel, CT
Is anyone running TTI exhaust or tail pipes with out chrome tips on the end ? I would like to see what the turn downs look like
68 Dart 3" TTI tail pipes
That's pretty cool when you ask a question in Conneticut and can have an answer from California in 8 minutes! :salut:
Sure is John.
Zandfull, Thanks for the picture. I like the turn downs much better then the slash cut on my currant tail pipes.
Here is the TTI exhaust on the 71 Demon.
But by using the turn down tailpipes, that means you can't run the chrome tips, correct?
You just have to cut the turn downs off and weld on the Chrome tips, now if you have ther 3" exhaust it may prove to be a problem, as I not sure if the Chrome tips come to fit 3" pipe.
You can sort of make them out on mine.
I just got the stainless tips for the 440 from Year One.
