jiw700
Scamper340
just wandering what your thought's are about complete system , manifolds to the rear of car. anybody tried them,
My friend has the complete system on his 67 SB Dart, and it fits and looks great.
I made the mistake of buying just the 2.5" tailpipes , they didn't fit right and the outlets are not in the stock location , but the 3" are ??? Biggest waste of money in my case ...
good luck ...
My 2.5" tail pipes exited exactly where they should lining up with my Formula S rear cut outs.
Unless they changed something they did not exit in the right place on a 68-69 Dart , they swing inboard of the frame rails after they clear the gas tank , the STOCK FACTORY mounts for my tips need the pipes to be directly under the framerail . Maybe the barracuda uses tailpipes like that and that's why TTi makes them like that , catering to the smaller segment of the market ??
To the question as to why it was a wate of money , the guy that hung them had to cut the pipes in front of the axle and rotate them or else the mufflers would have been in the framerails , unless he screwed up and put them on the wrong sides , I was no present , I would have saved the 189 for the tails by just having him bend me up some fresh tailpipes since I had to have him make headpipes because TTi doesn't make the front pipes for a big block A body with ANY manifolds .
I've got close to $900 in my exh and it looks like **** , the only nice parts are the accurate stainless tips .
The TTI system isn't "One size fits all" They don't just sell one tail pipe to cover all applications.
Only 2 possible problems here.
1. Your idea of the stock exit point is wrong.
2. You got the wrong tail pipes and didn't return them for the correct ones.
Both 1 and 2 would be your fault.
Your WRONG , it is a ONE SIZE fits ALL A bodies ... 67-76
Center section yes, could be but clearly not the tail pipes.
Sorry , the tailpipes are one size fits all , they only list 3 tailpipes ,63-66 , 67-69 barracuda and 67-76 A body
here is a pic of a 71 duster with 2.5" pipes , the same pipes I got and they are NOT correct for a 67-69 dart , hell a 67 A body only had a single tailpipe even with a dual exhaust .
http://www.ttiexhaust.com/Exhaust_Systems/p25-71Duster.htm
