Tubular Control Arms
draginmopars
Shady Hills, Florida
are control arms available-
Small ball joint,
with adjustable heim joints
want to free up control arm travel
70 Dart Swinger
thanks for looking for me..
if i read it right it says.
Application Notes:To be used with "big ball joint" spindle only.
Check their website. I know they sold them at one point in time. Summit just might not carry/list them.
Sorry I didn't read that carefully enough.
thanks, bob
I looked at them
takes the large ball joint
says can enlarge the early spindle to make them work
That's what I'm trying to get away from
I can do the work,
Just don't want to buy a tapered reamer to only use it once (or twice/both sides)
https://www.reillymotorsports.com/store/product.php?productid=16164
Uses 73-up style big balljoint, 72-older A-body spindles will not work
or can be machined to the larger taper -
I have the reamer but you will have to pay for it if you'd like to use it and get your money back after you send it back
thanks, bob
I looked at them
I can do the work,
Just buy the RMS ones and send Bill you spindles he will ream them for you for free.
I'll contact you later, Thanks
SpareParts- was trying to use the spindle i have, cause everything is new, bearings ,
ball joints, and brake parts.
All I want to do, is free up the arm movement
for quicker weight transfer
Got ya. I've made aluminum bushings for stock arms before, worked great on a budget. Unless you are also having trouble getting a good drag race alignment, then adjustable is the ticket. I make my own arms
Thanks, will have to look into that
We are Always on a budget, just never stick to it
always doing something to the car..:burnout:
