tunnel ram for /6
dirty white boy
50 yr old Juvenal delinquent
stoneville n.c.
Well alrighty then! That's kinda cool. Aussie Speed makes this one.
idk, found pic on FB, the pipe used looks to be at lest 3 1/2 to 4 inches around id hope hole in intake would at lest match it!
I'm not sure there's enough area in that spot on the intake to match the diameter on that piece of pipe. I'd want to take the carburetor off and see first.
if it dont open up to at lest match the cross section of the 4 holes in the carb base plate its pissing in the wind on a flat rock!
or, find a 2bbl intake, snap on a 2bbl ==> 4bbl a-dap-tor then stack a few spacers on.
you could fine tune it with different thickness and design spacers even!
