yakkier
1fine99
Alright i'v got a 383 out of a 79 Fury that i'm in the process of rebuildin from the crank up, now i want to try an turbocharge it considering i'v never seen it done, i'v seen 350's an v6 international's but never a mopar big/small block, so i figured it's worth a shot. So far i'v done some research an talked to the guys at Summit an Rouch an they all say the same thing, if i simply get a stroker kit with Eagle rod's i should be able to hold atleast 20 - 30 PSI an 40 max. I'v already got an innercooler of a 03 F250 desiel i'm in the process of designin the headers. Now the big part, i'v got a 99 Durango ( my baby ) with a 360 in it, i'm hopfully going to swap the 383 in an put the 360 in the fury. Now the main question is.. what do u guys think about the idea of a Big block mopar Spoolin TT's an runnin a 200 shot of nitro ?
Comment's good an bad are welcome
