74Dusted
Stock Piler of 340's
Where can I get a good quality new cam? Years ago I bought one of those "HELP" line replacement cams and installed it in my '74 Duster, you couldn't move the turn signal stalk at all. So I tore it back out and upon a close inspection I found that the HELP line cam was larger in every given dimension when compared to the broken original cam I removed.
I tossed the replacement Cam on the shelf and robbed/borrowed the original one from my '72 Demon.
Well that old cam was finally done last year. I'd have to hold the turn signal stalk up for right turns. And if I really put the car through its paces (twisting winding roads), the turn signals will flip themselves on from spinning the steering wheel in a rapid movement.
Since my car is going to be torn apart anyway for Paint & a 4-Speed conversion, I might as well replace that cam too. So where do I get a good quality one that actually works/fits
