Turn signal lever folppy
SF Bay Area
Not sure if I’m posting this in the correct thread so lmk if I’m not. I have a 1972 Duster and my turn signal lever is floppy and not working. Before I pull the steering wheel etc off, I wanted to get some insight on what the problem could be and what parts I need to fix it.
Could be the switch is busted or if you're lucky just the screw loose on the lever
