Lowfat37
Member
HI everyone. Greetings from central Washington State. I have a 73 Duster and am having trouble fixing this issue. I replaced the turn signal switch even though the old one did not look broken. Unfortunately, it did not fix the problem. I see I can buy the Horn Contact set from classic industries that includes the spring that is supposed to do the cancellation. I wondering if those wear down over time and don't make contact with the switch? Also wondering if there is a specific place they are supposed to orient on the steering wheel to function properly? All ideas are welcome!
Thanks!
Thanks!
