twin scoop placement 71 demon?
fstbackfish
SS/AA
montrose co
Does anybody know right off hand the hood scoop placement and measurements for the twin scoops on a 71 or 72 dodge demon?Any help would be greatly appreciated
-Josh
BTW -- if you look at the underside of the hood, you will see there are holes in the bracing where several of the mounting studs attach -- when I did my Demon, I just center punched each of those holes and drilled. I then used a grease pencil on the remaining studs and set the scoop on the hood, lined up with the drilled holes and marked the remaining holes I needed to drill. Make sense?
