[Found!] Twin Scoops Template
72DMag
Pittsburgh
Hello All,
Looking to see if anyone out there has a twin scoop template they no longer want. Will need it shipped to 15108. This template is used for mounting the scoops on the hood. Figured I ask before buying a new one. Thanks!
Since my scoops are aftermarket, I made my own template. I measured every stud to every other stud on each scoop and transferred those measurements to paper. I then located and center punched the 3 or 4 rear holes (through the bracing) and proceeded from there.
@DartGTDan Thanks!! Thats not a bad idea. I am more concerned with how far apart they are suppose to be from each other center to center. Honestly I might move them to the sides more. Instead of me buying a template then, do you happen to know that measurement? Thanks!
72DMag if you look at the bracing under the hood you'll see the pattern for where they mount. Somebody had posted, here on FABO, an under hood picture of holes and the bracing. Try a search for it.
The RED circles show a couple of the stud hole locations. The YELLOW circle indicates where the scoop seal would go. This is the driver side.
