JoJo
TF 727 valve body: Has around 550 miles on it and 4 track passes (1/8 mile) since the B & M Shift Improver Kit was installed. Valve body will work in a A-904 also. Just install and enjoy (Add new filter). Asking $60 shipped...
A-904 lock-up valve body: Is ready for your TransGo TF-3 kit. All fabrication work is already done except for the grinding of the 1-2 Governor and TV valve (used them in my non lock-up valve body). The only thing you'll need to do is swap the springs, install the new design manual valve, bolt up transfer plate, and remove check balls. You will need the 1-wire solenoid. One will be included, but the wire is missing. Asking $60 shipped...
