UCA dimensions outside to outside of bushing
They are identical uppers dimensionally... the difference is early a body's used small K704 upper ball joints until 73 then went to large K772 style, the B Bodys used K772 across the board. Gotta match spindles to ball joints and you'll be good. Both used the same upper control arm bushings.
No, no, no! Not identical dimensionally. Correct on the ball joints, though.
A body:
B body:
I'll try to get some A body dimensions for you this afternoon if nobody chimes in by then- can't help with the B body, though. Haven't had one of those in 20 years.
Edit: OMM beat me to it!
