under dash harness
whiteduster
i need to replace my harness engine and underdash non ac slant six i got a really nice ac harness how do i make the heater non ac heater work with out hot wiering it could it be possible to swap the some of the wires?
First order a wiring diagram from classiccarwiring.com for your car.
Or
You can download your cars Factory Shop Manual from MyMopar.com or even maybe a wiring diagram alone. (MyMopar.com is free download)
Then start tracing out the wires for each setup and see if you can repurpose some wires if need be.
You might need some plastic connectors if they are different from AC to non AC .
AC sub-harness is usually plugged into a base harness. You should be able to unplug the AC sub-harness and plug your non-AC stuff right in...
Pull out yours and lay them side by side. Most cars in general have the base harness with plugs to add and delete options.
