Undercarriage paint
ajarofclay
Chicago burbs, Illinois
Converting to late model disc brakes and need some opinions on what is best to paint miscellaneous parts and control arms with. I'm thinking undercoating paint? Any other opinions. I need to double check but I think I have to paint spindles, calipers Etc also.
Regular old paint. I use Eastwood paints as they offer different Argent/silver/grey combo's. For black I use Home Depot for flat/semigloss/gloss.
It does depend on what look you're going for.
I wasn't going for OEM correct but I wanted a look better than just painting everything black. I left many parts natural finish but coated them with RPM paste:
This helps the parts stay looking fresh.
Otherwise, I'll paint other stuff a semi-flat black.
You can use spray cans but you'll get a more durable finish using catalyzed enamel sprayed from a gun. I always use etching primer on bare metal first.
