[FOR SALE] Universal Tri Power Setup
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
Vintage Speed adapter
Carbs
Progressive linkage
Carbs, identical venturis, throttle blades, boosters.
They aren't original carbs from a tri power set up like Pontiac
Center carb looks like a manual choke 327 trk carb, note the vent on top of the bowl
The only mods required are soldering the idle circuit holes closed.
Benefit, only working idle 2 screws are in the center carb vs 6.
Mikes Carbs has everything u need to refresh them
The tip on 1 accelerator pump arm is rusted off, if you want the set up I will find one.
This in no way reflects the condition of any of the carbs, isolated event
$800 shipped
I ran a set up similar to that on a Ford flat head a "lot" of years ago. It was a carburetor tuners nightmare back then, I could never get the tuning correct due to the low plenum. Carburetor kit technology has come a long way since then. Good luck with it.
