i have the crank, reconditioned and resized stock rods with arp bolts, and a set of 360 188, 360 heads. any ideas as of cam and good pistons? i was thinking anything on a 114 deg lsa and around 8:1 comp. i spend about an hour talking to the guy from the supercharger store today.
Can't help with your engine question.....I 'm from around Lafayette. Good to see more Coonasses around here!! When's crawfish season starting up again? :tongue:
8.0:1 should be good for compression. You should talk with the guys from the supercharger store or one of the cam grinders for a specific cam. They should be able to come up with a grind to do what you want your engine to do.
the lobe seperation sounds good (114) thats good for a s/c the tighter you go (lower numericly) the less pressure the charger can build (making the s/c less efficient) i learned this when i had my 144 charged 305 camaro......
i called the supercharger store and they were great. told me every possible thing that i would want to know, and they are sending me a book on supercharging. now i just have to get the money saved.........
