Update on the 373 build
Small Block Mopar Engine
  1. MoparMark91
    MoparMark91 Well-Known Member
    525
    162
    Jun 22, 2018
    CA
    Local Time:
    9:59 PM
    Hey guys well after the transmission debacle plus the shift cable I fixed that. Here is a video of it idling warmed up after I went for a drive, so far put about 250 miles on the build about to do first oil change (even though I had to do a oil change of break in oil due to being paranoid) lol
    So as many ofsof you may know this is first build, today I had after driving for about 1 hour and it was pretty hot out my oil pressure pressure after driving around in about like 96° and it was about 12-15 idlling on the hot side (it did feel hotter than that). Is that normal pressure with high volume pump 30w break in and clearances were .0025. just curious and probably being paranoid but tomorow I plan to make the first oil change to 10w40. I am also using a short sweep electrical Guage so maybe I need to get some more precise mechanical wide sweep? I understand I might be overthinking this as well. Oh yeah and for the ones that are curious how the cam came out for my build, with a 3000k stall 9 1/2 , this thing rips lol it's very quick off the line. Impressed my little girl when I was at the stoplight with the wife and kids in the family car and i attempted to launch and it didn't get traction for about 80 feet and I had to peddle it out since I was going into my wife's lane with the rear leading lol(I don't if that would be right term) but anyways the cars drives great gets a little hot in CA stop and go traffic but loves to run. Got about 10 initial timing in it. Have a mechanical fan and switching to dual electric. I will say the car is a blast to drive out of all the years I've owned it omg it's so much fun going out on old road just cruising with the occasional throttle moments lol. Thank for all the help guys and I appreciate as I am still learning and always will be. Got a buttload of parts sitting in the garage ready to go in just need time and still needs proper tuning lol (plan on doing qa1 strut rods,transmission cooler+ plus new deep pan alternator(upgraded due to electric fan update upcoming) and a bunch of stuff and parts I've been procrastinating to put on lol
    • Like Like x 3
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      65,791
      39089
      Jun 7, 2010
      Georgia
      Local Time:
      12:59 AM
      Just curious, how did you arrive at 373 cubes?
    • MoparMark91
      525
      162
      Jun 22, 2018
      CA
      Local Time:
      9:59 PM
      So I'll be straight honest when it comes to displacement I don't know whether you round up or not cause I am at a 372.6 was looking at my scat kit recipets and it said 373 so I figured it's rounding up lol
    • RustyRatRod
      65,791
      39089
      Jun 7, 2010
      Georgia
      Local Time:
      12:59 AM
      That's what I'd do. What's the bore and stroke?
    • RustyRatRod
      65,791
      39089
      Jun 7, 2010
      Georgia
      Local Time:
      12:59 AM
      Ford rounded up the 302 in both cubic inches and liters. They advertise it as a 302 and it's a 301 and does NOT round up. It also works out to be a 4.9 and does NOT round up that way either. LOL
      • Agree Agree x 1
      • MoparMark91
        525
        162
        Jun 22, 2018
        CA
        Local Time:
        9:59 PM
        4.07 bore
        3.58 stroke
        Lol may not be a 408 but I do like it and I'd say good for my first build performance wise
        • Agree Agree x 1
        • RustyRatRod
          65,791
          39089
          Jun 7, 2010
          Georgia
          Local Time:
          12:59 AM
          Ok gotchya. Hell that'll work.
          • Like Like x 1
          • 65 Dartman
            65 Dartman FABO Gold Member FABO Gold Member
            11,763
            3306
            Sep 24, 2006
            Strasburg, VA
            Local Time:
            12:59 AM
            sounds like the marketing guys had their hands in the description
            • Agree Agree x 1
            • RustyRatRod
              65,791
              39089
              Jun 7, 2010
              Georgia
              Local Time:
              12:59 AM
              Indeed, for sure. I wouldda done the same thing, though. How ghey does 4.9 or 301 sound? Especially for a Fox body performance car. GHEY lol
              But, by the same token the 400 Ford, a Cleveland family motor has a 4" bore and a 4" stroke. Longest stroke pushrod motor Ford ever made, yet do the math on that and you get 402. lol
            • jimjimjimmy
              jimjimjimmy lobsterman FABO Gold Member
              4,493
              1280
              Nov 2, 2010
              p. e. i.
              Local Time:
              1:59 AM
              my 418 small block with straight 30 has 70 psi cold , hot idle is 45 psi and hot cruse is 55 psi . i have a deep pan and regular oil pump . just for reference .
              • Like Like x 2
              • kursplat
                kursplat FABO Gold Member FABO Gold Member
                3,601
                2466
                Aug 24, 2010
                so cal
                Local Time:
                9:59 PM
                fox body? come on, you're older than that. i hear 302 i don't even think of anything built after 74' :lol:
                the car's coming along MoparMark91. that idle pressure is fine
                • Like Like x 1
                • 273
                  273 Well-Known Member
                  3,403
                  1130
                  May 14, 2012
                  Ontario
                  Local Time:
                  12:59 AM
                  Not to nit pick I got 301.59 lol
                  funny thing I notice with 4 inch bores is if you take any stroke like 2.87" 3.00" 3.25" 3.48" 3.58" 4.00" etc.. if you drop the decimal point and add 2 to it you get the displacement 289 302 327 350 360 402 etc..
                  To the OP is that a 340 or 360 block ?
                  • Like Like x 1
                  • MoparMark91
                    525
                    162
                    Jun 22, 2018
                    CA
                    Local Time:
                    9:59 PM
                    Thanks, looks like I even inspired a guy with a a body cuda to bring his out yesterday it was really nice and I know he was putting out some power by how he pulled out of his driveway lol
                  • MoparMark91
                    525
                    162
                    Jun 22, 2018
                    CA
                    Local Time:
                    9:59 PM
                    It is a 340 block with a scat forged kit in it.
                    All the drivetrain has been swapped over, it's just crazy watching the transformation from what it was lol
                    • Like Like x 2
                    • Jadaharabi
                      Jadaharabi FABO Gold Member FABO Gold Member
                      7,873
                      8667
                      Jan 8, 2016
                      Peoria, Illinois
                      Local Time:
                      11:59 PM
                      Glad to hear your driving it.
                    • Rocket
                      Rocket FABO Gold Member FABO Gold Member
                      2,019
                      288
                      Apr 22, 2005
                      Manchester, CT
                      Local Time:
                      5:59 AM
                      Break in oil is often thin and your switch to 10W40 will likely increase the oil pressure a little but not a lot . Trying a good mechanical gauge is a good idea to validate your pressure.
                      • Like Like x 2
                      • Nat
                        Nat Well-Known Member
                        452
                        243
                        Jun 11, 2019
                        Netherland
                        Local Time:
                        5:59 AM
                        REALLY DON'T THINK THE CHANGE IN OIL will bring the pressure up that much , but it can't hurt . GOOD GAUGE is a great idea the factory and many aftermarket electric gauges are not reliable
                        • Like Like x 1
                        • QuickDart360
                          QuickDart360 Well-Known Member
                          1,259
                          470
                          Apr 5, 2014
                          San Antonio
                          Local Time:
                          11:59 PM
                          Mind sharing cam specs? Hydraulic or solid?
                        • MoparMark91
                          525
                          162
                          Jun 22, 2018
                          CA
                          Local Time:
                          9:59 PM
                          Mine? I'm running hyd XE275HL
                          I believe off top of my head intake 231 exhaust 234 with 525 lift on both. Works amazing with a 3k stall
                          • Like Like x 1
                          • Wyrmrider
                            Wyrmrider FABO Gold Member FABO Gold Member
                            3,611
                            1732
                            Sep 5, 2016
                            los angeles
                            Local Time:
                            9:59 PM
                            good to know
                            What's your mech comp ratio Mark
                            and cranking compression and details on your build
                          • MoparMark91
                            525
                            162
                            Jun 22, 2018
                            CA
                            Local Time:
                            9:59 PM
                            Static 11.4 or so I believe if I remember right
                            Dynamic cranking ratio 8.79
                            Cranking pressure 182
                            Aj helped me with calculation when I was building it but I changed my quench to a .040
                            Once I get home I will check my notes on my desk I might be off a bit give me a bit and I'll redo the math
                            Eddy stock heads closed chamber
                            Scat rotating forged internals 3.58 stroke
                            HV oil pump
                            Air gap intake with 1 inch spacer
                            Comp roller rockers
                            Msd dizzy mechanical
                            Mad ignition box
                            Doug's headers
                            Holley 650
                            727 trans with b & m shift kit
                            3k stall
                            3.23 gears
                            1.03 torsion bars
                            Boxed lower control arms
                            I'm at work but will add the rest on next break
                            • Like Like x 1
                            • Wyrmrider
                              3,611
                              1732
                              Sep 5, 2016
                              los angeles
                              Local Time:
                              9:59 PM
                              looks like one of my builds from 40 years ago with ported 915 heads and trw 6 pack pistons
                              no edelbrock heads or A J
                              no roller rockers- bushed Isky, Grant CD, no air gap but TQ
                              engine still on the road
                              Engle solid cam,ISKY dual springs
                              THANKS
                            • Jadaharabi
                              7,873
                              8667
                              Jan 8, 2016
                              Peoria, Illinois
                              Local Time:
                              11:59 PM
                              I guess you could say it looks the same only different.
                              • Like Like x 1
                              • Wyrmrider
                                3,611
                                1732
                                Sep 5, 2016
                                los angeles
                                Local Time:
                                9:59 PM
                                yeah about the same combustion chamber, his is better, quench, compression
                              • oldkimmer
                                oldkimmer FABO Gold Member FABO Gold Member
                                16,893
                                5134
                                Nov 11, 2006
                                Kindersley, Saskatchewan,
                                Local Time:
                                11:59 PM
                                Glad ur having fun. Sounds great. Kim
