1. GSXcite
    GSXcite Well-Known Member
    278
    73
    Oct 11, 2011
    Kansas City, Mo.
    Local Time:
    1:17 AM
    Just rebuilt upper a arms on my 66 barracuda. I noticed a collar on the old rear bushing after I pressed in the new bushing. The new bushings did not have a collar. Is it necessary to have this collar, and where would you get one if needed.
  2. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    11,003
    5462
    Nov 28, 2008
    NorCal
    Local Time:
    11:17 PM
  3. GSXcite
    278
    73
    Oct 11, 2011
    Kansas City, Mo.
    Local Time:
    1:17 AM
    Yes that is the ring I have on my old bushing. I can't see where it would do anything to stop the bushing from moving. The old ones are so pitted and rusty I would never be able to remove them to use on the new bushings. Have any of you installed new a arm bushings without the sleeve and had no problems with not using them?
  4. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    11,627
    3207
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    2:17 AM
    Talk to @hemi71x about those bushings. I think he might have a few rust-frees for sale
  5. cudamark
    cudamark FABO Gold Member FABO Gold Member
    7,200
    460
    Mar 14, 2009
    San Diego
    Local Time:
    11:17 PM
    They're not necessary as long as your bushings fit tight in the control arm, or you're doing some serious corner carving. If you are, you should be getting some aftermarket suspension parts more suitable for that.
  6. GSXcite
    278
    73
    Oct 11, 2011
    Kansas City, Mo.
    Local Time:
    1:17 AM
    No corner carving for me in the barracuda. I have a hayabusa and a Miata for those urges. Going to go without them . Thanks for the reply's.
