ok, I am about to get into the suspension on my sons 73 Dart Sport. I am replacing upper and lower ball joints along with inner and outer tie rod ends. Looking at the upper ball joints. It has been 40 years since I have messed with the front end on a Mopar so I am thinking that you take the nut off the bottom and use a separater to drive these up and out the top. Is that correct or is there a better way. the lower looks simple and so does the tie rods. Thanks,Bill
