Upper Ball Joints
philsauto
Member
spring texas
I Want To Put Disc Brakes On My 67 Cuda. I Know The Upper And Lower Ball Joint Are Different. My Question Do You Have A Different Upper Control Arm, Are Is It Just A Ball Joint Swap. Thanks Your Help
Yes, the ball joint is larger in diameter on the later model disc brake set up, so you have to get the upper control arm that goes with it.
