upper control arms
sb3854
Active Member
tucson, az
Does anyone know what the outside to outside measurement of the bushings on a 67 a body upper control should be?
About the same as the inside to inside measurement of the tabs it mounts between.
My 72 looks to be just under 9-1/2". Tough to be exact with the UCA and rest of the suspension installed.
67-76 should all be the same.
