65Vart
Hello, where can I get just the upper speedo cable for my 71 Dart, All I seen to be able to find is a long one piece unit direct to the tranny. Is that the fix?
I need an upper which is about 24" long with the plastic clip on at the speedo end.71 should have the clip on end if its original. Screw on at the speedo ended with 67 model.
If your car happens to have cruise control there would be seperate upper and lower cables. That upper cable would be very similar in any Chrysler product.
