[SOLD] Used 318 long block and A230 3spd $300 takes it!
MonkeyMadness
Yorba Linda California
Looking for a loving home... NEED it GONE!
$300 takes everything ( except oil pan and valve covers)
I have a used 69 318 long block -less oil pan/valve covers.
3spd A230 w/ 30 spline tail shaft. Bell housing flywheel clutch and presure plate included
I also have a 2bbl single plane manifold
Everything is pickup only in the orange county area SoCal.
Thanks
J
Looking for that linkage but for an A Body.Not likely the same linkage,man you have no idea how excited i was to think i actually found the correct linkage.Search continues
Do you have any pictures or measurements of the linkage you need? Which parts are you hunting for exactly?
and for which car?
The 2 shift rods that go on the levers (on the transmission that you posted pictures of) to the steering column. My car is a 1971 Dodge Demon
