[SOLD] Used 4-bbl throttle cable bracket with most of the carb kickdown parts plus the return spring bracket
physixx
Edison, NJ
I have for sale a throttle cable bracket with most of the carb kickdown parts along with a throttle return spring bracket that came from a 1972 340/727 application.
Herb's Parts: 1972-73 340 Throttle Cable Bracket, Throttle Cable Springs and Brackets, 561
I’m sure that it’ll fit more engines and years. Also included is the trans kick down lever. The only thing missing for this setup is the long rod that goes from the cable bracket to the trans lever. This is for the 4 barrel setup. All the parts are clean and don't appear to be damaged from what I can see. Everything except the trans lever has been painted. I would like to get $65.00 for everything plus the shipping.
Ken
Edison, NJ
My in box is full and having problems just give me a few minutes and I’ll pm you
